Hey guys iv looked through the check list and dont see anything that helps me. Il just post up what i have so far.
The Motherboard is Gigabyte MA7885GT-UD3H
Cpu is Amd Athlon 620 II x4
Graphics card Ati 4850
Psu Corsair 650w
Memory Xms3 corsair 2x1Gb DDR3
I went through the motherboards manual carefully
Ok Here my checklist
Cpu and cooler on and cpu fan wire in -
2x12 Main power connector In from psu -
Graphics card in the PciEx16_1 Slot (Which im not too sure is right but i think it is)
Forgot to plug in the 4 pin connector but pluged it in and tryed again and still nothing.
sata2 cable in to hard drive/sata1 slot (There is a 0 also but its under) which is a Seagate barracuda 7200 ( had it quiet a while)
Graphics card pluged in to screen..There is onboard graphics i believe and i tryed it in that port too but still no luck..
I wore an antistatic wristband when i was touching everything.
Gpu and cpu cooler fans both come on when i try turn it on
It is more than likly somthing simple but i cant find it.. btw im a beguinner builder
Thanks guys !
Psu Corsair 650w
Thanks guys !
