Tom's Hardware > Forum > Graphic & Displays > ATI > Graphic problem
Graphic problem
Forum Graphic & Displays : ATI - Graphic problem
Hi...i having problem regarding playing games!!!
wel i have install Burnout(TM) Paradise The Ultimate Box...game. Bt m having problem playin this game..it gives me error that " ur system does not support shader 3.0"
wel m listing my system config below:
System Model: GA-MA74GM-S2
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, MMX, 3DNow (2 CPUs), ~3.0GHz
Memory: 2GB RAM
Card name: ATI Radeon 2100 Graphics
Display Memory: 700.0 MB....
wel my system drivers r also upto date!!!
wel wat shud i do??? havin same problem with need for speed-shift and devil may cry 4....
U can also mail me on this id :---gaurav_debu@yahoo.com
Sponsored Links
that error means you can't play the game, Shader Model 3.0 is needed and your card doesn't support it, there is no software update as shader model is hardware based
this means time to get a new gpu, or in your case get one (as the HD2100 is not a discrete card)
Reply to mindless728
You have Integrated Graphic card which is crap.
Even if it had Shader model 3.0 it is such a weak card that it won't even run the game at lowest settings.
In order to play that game and all latest games you'll need to upgrade your GPU.
Reply to shubham1401
I wonder why they bother puting those stupid "Minimum System Requirements" on the box...........Oh yeah, now I remember......
Reply to zipzoomflyhigh
You're not having a problem. The problems that are posted here are usually associated with software errors in BIOS settings, RAM timings, etc....
Your hardware simply can't handle that game.
Reply to HundredIslandsBoy
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
