Hi guys!
I'n new to the over-clocking world, and new the forums too.
I've searched through the forums on this site (and everywhere else on the internet) for help and can't find anything. I've done quite a lot of reading up and learning so I'm trying not to ask too many dumb questions!
I've currently got a basic setup with the hope of upgrading when I finish uni and get some cash!(current system specs are below) I added a water cooling loop on the CPU to make it all a bit quieter and am getting nice low temps with almost silent running - so all's well in that department.
As part of my course I run many computer simulations (taking anywhere from an hour to several days) and I want to overclock so I can run them faster. I also use my pc for gaming, but not too often.
Current system specs are:
i3-540
asus P7H55-M/USB3
(2x4Gb) Corsair Vengeance DDR3 PC3-12800(1600)
GTS450
I don't seem to be able to change the multiplier on my cpu even though various sources on the internet say its unlocked...So I've had to go down the BCLK frequency route.
I started overclocking with the asus turboV EVO program so I didn't have to keep restarting my pc. I went up in steps of 10MHz from the standard 133. All was going smoothly but I realised the RAM freq was getting high.
at ~150MHz BCLK the pc just shutdown and restarted at the default 133MHz.
I figure I need to change the dependence of the DRAM freq to FSB freq?? (I assume I'll probably have to do the same with the PCI settings?)
but I've looked though the BIOS and cant find out how.
Any help from you guys would be greatly appreciated!! Have I even identified the source of my problem correctly?
Thanks in advance,
Pete
i3-540
asus P7H55-M/USB3
GTS450
Thanks in advance,
Pete
