First off let me say thanks to dndhatcher which has helped me tremendously come up with this list of parts. Also want to clarify that this computer is not going to be used for any gaming, so the integrated HD4200 should be sufficient, but I don't want to go any lower. If you guys have any other ideas or deals please let me know.
This is the CPU and Motherboard $180.00
I decided to go with AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W Quad-Core
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.276969
Memory sticks $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
This is the case and power supply $107
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.288426
Hard Drive $56
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Although I think I am going to try to reuse my old HDD if possible. It is also a samsung 400gb though and has Windows Vista on it + all my files that i don't want to lose so I am trying to research whether I can use it or not as the master drive.
This is my old HDD for what it's worth
http://www.newegg.com/product/product.aspx?Item=N82E16822152046
I am also going to use my old DVD drive
http://www.geeks.com/details.asp?invtid=BLK-TS-H653-DO&cat=DVD
Let me know if you guys have any advice regarding different options to upgrade, compatibility etc.
Memory sticks $70
Hard Drive $56
