Having the same issue. This is probably a RAM incompatibility with the motherboard. Try to put one stick of modules into the white slot next to the CPU, then start the computer. Enter BIOS and load optimized defaults. restart the computer.
Turn it off then you can add the other module (if using dual channel).
If this doesn't help, use one module in the slot and reduce speed in BIOS (under M.IT) to 1066 or 800.
