Hey guys! So firstly, thanks for taking the time to check out this post and trying to offer some help. This is my first time on the forum so forgive me if I miss something.
SO what I'm doing:
Currentlly I'm in the process of re-upgrading my computer. I have an EVGA Nforce 750i SLI FTW with Core2Quad 9400 (2.67GHz) and currently connected to it are two aging BFG 7800GTX (yeah BFG aren't even around anymore), OCZ 1066 DDR2 SD RAM (PC 6400) 2 X 2GB, 550 W Antec PSU, and two harddrives: a really old WD 160GB and WD Cacviar Blue 500GB (Master). To top it off everything runs on WinxP.
So what I'm putting in now is:
Crucial m4 SSD 128GB
ASUS ENGTX460 1GB OC
Win 7 Professional (working with the student upgrade, I'm planning on doing a clean install by installing twice, since I've burnt the .iso to disk, I'll install the first time without product key and then re-install with product key. The laptop I'm using is a successful victim.)
So I've migrated everything but the two new parts into a new computer case. I'm currently backing up files from both the old HDD and the Caviar onto external's, so I can wipe the two drives. But I know that I'm supposed to upgrade the firmware on my SSD before I install.
So should I plug in the SSD to the system as is, let windows xp detect it, and then download new firmware for it and then - THEN - wipe the drives, make the SSD master and install winxp onto the SSD, followed by upgrading to win 7, then re-installing win 7 as a clean install??
(Phew that was a heck of a run-on sentence) I'm sorry if this is a bit confusing.
If anyone can tell me a better way to sort this little mess out, I'd be super happy.
It's been a while since I've jumped into building again, and what's really got me worried is playing around with SSD's.
Please help!
And do ask if anymore info is needed.
Thanks,
NaryaMithrandir
SO what I'm doing:
Please help!
Thanks,
NaryaMithrandir
