Tom's Hardware > Forum > Homebuilt Systems > New System Build > First Build, *Please Help*
Forum Homebuilt Systems : New System Build - First Build, *Please Help*
APPROXIMATE PURCHASE DATE: ASAP, This Weekend?
BUDGET RANGE: 800 Before Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming
PARTS NOT REQUIRED: Dell SP2009W 20-inch 2ms 1680x1050
PREFERRED WEBSITE(S) FOR PARTS: Newegg
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: None
OVERCLOCKING:
SLI OR CROSSFIRE:
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS: This is my first build, Is everything compatible or am I missing anything? Also do I need a better heatsink then stock, I'm probably not gonna OC.
Cart Item List:
Qty. Product Description Savings Total Price
http://www.newegg.com/Product/Prod [...] 6820146871
Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory
Item #:N82E16820146871
Return Policy: Memory Standard Return Policy
$99.99
http://www.newegg.com/Product/Prod [...] 6811129066
Antec Three Hundred Illusion Black Computer Case
Item #:N82E16811129066
Return Policy: Limited Replacement Only Return Policy
-$10.00 Instant
$69.95
$59.95
http://www.newegg.com/Product/Prod [...] 6823126013
Logitech Deluxe 250 Black Keyboard
Item #:N82E16823126013
Return Policy: Standard Return Policy
-$4.50 Instant
$14.99
$10.49
http://www.newegg.com/Product/Prod [...] 6822152181
SAMSUNG Spinpoint F3 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
Item #:N82E16822152181
$54.99
http://www.newegg.com/Product/Prod [...] 6836121013
Logitech S120 2.0 Speaker System
Item #:N82E16836121013
$14.99
http://www.newegg.com/Product/Comb [...] mbo.273353
ASUS M4A79XTD EVO ATX AMD Motherboard
Item #: N82E16813131402
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor
Item #: N82E16819103649
Return Policy: CPU Replacement Only Return Policy
-$5.99 Instant
-$27.00 Combo
$10.00 Mail-in Rebate Card
$244.98
$211.99
http://www.newegg.com/Product/Comb [...] mbo.274500
Antec TruePower New TP-750 750W Continuous Power "compatible with Core i7" Power Supply
Item #: N82E16817371025
SAPPHIRE Radeon HD 5770 (Juniper XT) 100283L Video Card
Item #: N82E16814102858
Return Policy: VGA Standard Return Policy
-$45.00 Instant
-$40.00 Combo
$20.00 Mail-in Rebate
$329.94
$244.94
http://www.newegg.com/Product/Comb [...] mbo.282129
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
Item #: N82E16832116754
Return Policy: Software Return Policy
Sony Optiarc DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B
Item #: N82E16827118030
-$8.00 Combo
$134.98
$126.98
Grand Total: $824.32
Message edited by Nokturnalz on 11-06-2009 at 07:37:04 PM
Sponsored Links
Your PSU is much more powerful than needed. 500w will do nicely and it saves you some money to spend elsewhere.
Cheaper RAM (1333MHz and CL9) will yield identical performance and save you another few dollars.
Combined, these two savings should allow you to get a 955 or at least a 945. A quad core CPU is always handy to have.
Do you really want to the LED lights on the case? The regular 300 is great as well, and somewhat cheaper.
Reply to Silmarunya
Ty for reply,
Would it be better to stick with this powersupply if I wanted to go crossfire down the road?
Also CL9 vs CL7 ram is it a big difference in gaming at all?
Guess it would be a nice trade to squeeze in http://www.newegg.com/Product/Prod [...] -_-Product
Message quoted 1 times
Message edited by Nokturnalz on 11-06-2009 at 07:49:13 PM
Reply to Nokturnalz
This OCZ PSU will save you some $$
Similar mushkin RAM with a $15 rebate
http://www.newegg.com/Product/Prod [...] 6820146868
With the $$ saved, you may be able to get this AMD 945 quad core in your budget
http://www.newegg.com/Product/Prod [...] 6819103675
Here's a promo code for that version of windows 7 - $102
EMCMMLS36
Message edited by aford10 on 11-06-2009 at 07:51:30 PM
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
The 5770 only uses one PCIE power cable and is a low power usage card. A good 550W PSU with two cables will be adequite for two 5770s.
I just checked xfxs website and they have it wrong. I have one of their 5770s and it only needs one power cable. That OCZ Fatal1ty linked by aford is a great deal right now.
Message edited by dndhatcher on 11-06-2009 at 08:02:36 PM
Reply to dndhatcher
Alright ty, Rebuilt it, looks good so far for about same price, But the Graphics card just got sold out lol.
Reply to Nokturnalz
The regular 300 is only $5 cheaper and does not have the two front fans. $5 for two $15 front fans pre-installed seems a good deal to me.
Reply to dndhatcher
Nokturnalz wrote :
Ty for reply,
Even for crossfire, it's more than needed. But if you want to keep it, go ahead. It's good quality.
The difference between CL7 and CL9 is noticeable in benchmarks, but not in everyday gaming.
It certainly would be a nice choice. Be aware the 945 has limited overclocking potential though (dunno if that's important to you).
Message edited by Silmarunya on 11-06-2009 at 08:32:57 PM
Reply to Silmarunya
True! Sorry, that Illusion case is new to me. It's not sold in Europe so I didn't knew it had more fans. The regular 300 is cheaper here, so I misjudged the difference.
Message edited by Silmarunya on 11-06-2009 at 08:34:03 PM
Reply to Silmarunya
Your PSU/video card combo expired.
If you want to get the AMD 945 in your budget, look at the suggestions I made in my 1st post. You can change a few parts to make up the difference without loosing any performance, other than the PSU wattage.
Reply to aford10
I changed around some of the stuff, but budget didn't stretch far enough to fit in the quad-core with shipping but I saved a bit, Is the quad core gonna be a noticable difference vs the triple? Also how does everything look?
Cart Item List:
http://www.newegg.com/Product/Prod [...] 6814161306
HIS Radeon HD 5770 (Juniper XT) H577F1GDG Video Card
Item #:N82E16814161306
$174.99
HIS Gamer's Tool Kit Model HGTK01-SB
Item #:N82E16814999013
$14.99
Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory
Item #:N82E16820146868
$15.00 Mail-in Rebate
$98.99
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5
$54.99
Logitech Deluxe 250 Black USB Wired Standard Keyboard
-$4.50 Instant
$14.99
$10.49
Logitech S120 2.3 Watts (RMS) 2.0 Speaker System
$14.99
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
-$10.00 Instant
$69.95
$59.95
http://www.newegg.com/Product/Prod [...] 6817341022
OCZ Fatal1ty OCZ550FTY 550W Power Supply
Item #:N82E16817341022
-$25.00 Instant
$25.00 Mail-in Rebate Card
$89.99
$64.99
http://www.newegg.com/Product/Comb [...] mbo.273352
AMD Phenom II X3 710 2.6GHz Socket AM3 95W Triple-Core Processor
Item #: N82E16819103648
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
-$27.00 Combo
$228.99
$201.99
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B
-$8.00 Combo
$134.98
$126.98
Grand Total: $808.36
Message edited by Nokturnalz on 11-06-2009 at 11:13:32 PM
Reply to Nokturnalz
Yes, there's a noticable difference in the 2 CPUs. The quad has a faster bus to go along with an extra core, and more memory.
How much short are you from getting the 945?
You could change to a different case to save a few $$ w/out affecting performance.
You could drop the 5770 and get the 4870 if dx11 isn't at the top of your priority.
It's really up to you. I'm just throwing options out there.
Reply to aford10
Alright I decided to drop a few extra dollars for the quad, You sure the power supply is gonna enough for everything? Here is the final build, Everything look okay? Stock heatsink fine? Wish me luck =)
Gonna buy it tonight!
select item 1 quantity of item 1
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811129066
-$10.00 Instant
$69.95
$59.95
select item 2 quantity of item 2
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152181
$54.99
select item 3 quantity of item 3
HIS H577F1GDG Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Item #: N82E16814161306
Protect Your Investment (expand for options14-161-306S6040|hide options14-161-306S6040)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info14-161-306.0.18)
* 1 year: $19.99
* 2 year: $35.99
$174.99
HIS Gamer's Tool Kit Model HGTK01-SB - Retail
Item #: N82E16814999013
-$14.99 Saving
$14.99
$0.00
select item 5 quantity of item 5
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
Item #: N82E16817341022
Protect Your Investment (expand for options17-341-022|hide options17-341-022)
The product will be replaced and shipped directly to you at no charge(more info17-341-022.0.18)
* 1 year: $10.99
* 2 year: $16.99
-$25.00 Instant
$25.00 Mail-in Rebate Card17-341-022
$89.99
$64.99
select item 6 quantity of item 6
Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM
Item #: N82E16836121013
Protect Your Investment (expand for options36-121-013|hide options36-121-013)
The product will be replaced and shipped directly to you at no charge(more info36-121-013.0.18)
* 1 year: $6.99
* 2 year: $11.99
$14.99
select item 7 quantity of item 7
Logitech Deluxe 250 Black USB Wired Standard Keyboard - OEM
Item #: N82E16823126013
-$4.50 Instant
$14.99
$10.49
select item 8 quantity of item 8
Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model 996652 - Retail
Item #: N82E16820146868
$15.00 Mail-in Rebate20-146-868
$98.99
select item 9 quantity of item 9
http://www.newegg.com/Product/Comb [...] mbo.273338
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 125W Quad-Core Processor Model HDX945FBGIBOX - Retail
Item #: N82E16819103675
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
Protect Your Investment (expand for options13-131-40210|hide options13-131-40210)
The product will be replaced and shipped directly to you at no charge(more info13-131-4021.0.18)
o 1 year: $16.99
o 2 year: $25.99
-$30.00 Combo
$10.00 Mail-in Rebate Card13-131-402
$285.98
$255.98
select item 10 quantity of item 10
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
Protect Your Investment (expand for options27-118-03020|hide options27-118-03020)
The product will be replaced and shipped directly to you at no charge(more info27-118-0302.0.18)
o 1 year: $6.99
o 2 year: $11.99
-$8.00 Combo
$134.98
$126.98
Subtotal: $862.35
Calculate Shipping Zip Code: . GO
Shipping: $30.70
Redeem Gift Certificates
Claim Code:
Security Code: Redeem
Gift Certificates: $0.00
Apply Promo Codes: Enter up to 5 promo codes, Please note that stacking is not permitted. What's this?
Promo Code: Apply
(For Example:code1,code2,code3,code4,code5)
|Click here to clear promotion code(s).
Free ShippingCharge From Promo Code EMCMMLP22
Promo Code: -$14.99
No Interest for 6 Months on orders over $500 or 12 Months on $999 or more.
Subject to credit approval.
Grand Total: $878.06
Message edited by Nokturnalz on 11-07-2009 at 12:05:29 AM
Reply to Nokturnalz
That's a nice looking build. Good job. Good luck with the build!
Reply to shortstuff_mt
I like it! I think you'll be happy with the 945 choice.
Reply to aford10
Ty all so much for your help, greatly appreciated. =)
Reply to Nokturnalz
That is a very nice computer for only $878. Well done!
------------------------------ Learn How to build a computer or see my recommended computer parts to buy.
Reply to AtomicDumpling
Everything turned out awesome so far, I'm on it right now, love this thing haha. The only problem im having is when I reboot/startup it says Hard Disk is not detected yet everything seems fine, was hoping maybe someone could throw me a hand on that?
Message edited by Nokturnalz on 11-12-2009 at 03:55:51 AM
Reply to Nokturnalz
I would check your BIOS settings. Make sure your hard drive is set as the 1st boot device and make sure there isn't a hard drive delay set.
Reply to aford10
There are 1174 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
