Tom's Hardware > Forum > Homebuilt Systems > New System Build > Good Water Cooling Case?
Forum Homebuilt Systems : New System Build - Good Water Cooling Case?
I'm building a PC which will sit next to my HDTV. Primary use for this machine will be gaming, and Blu-Ray, with office functionality in a secondary role.
To that end, I'm considering water cooling as it is quieter and provides better performance. I'd appreciate any suggestions for a good case to use, which will allow me to cut a template in the top for the radiator at a later date. I've looked at the Corsair Obsidian, and a few Silverstone models, and while these are undoubtedly great cases, I wish I knew if it was worth it to be spending over $200 for just a case. If I can get by with something cheap (but still solid) I'd like to do that.
Sponsored Links
Once you buy a case in the $150~$250 range, you'll never go back to crappy $50 or even $100 cases. The Lian Li http://www.newegg.com/Product/Prod [...] 6811112159 is awesome, but is a tad over your price range. This Lian Li is also cool http://www.newegg.com/Product/Prod [...] 6811112243 .
Buf if you're on a tight budget, the NZXT Panzer Box http://www.newegg.com/Product/Prod [...] 6811146056 is also good for water cooling.
Message edited by masterasia on 11-06-2009 at 11:27:39 PM
Reply to masterasia
I've beard of some people getting he antec 300 or 900 and mountin a rad under the giant 200 mm fan sitting on top of he case
I also have the antec 900 and the loudest thing in my case is the graphics card, with the 200 mm on full and the 120 mm exhaust fan on medium
Reply to wsupduck
There are 715 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
