Side panel removal
Forum Homebuilt Systems : General Homebuilt - Side panel removal
How can I remove the side panel(component acess)from my Cosmos 1000?
Sponsored Links
You can start off by reading the case owners manual. Here's the lazy man answer:
http://hi-techreviews.com/reviews_ [...] /Page2.htm
"On the side of the Cosmo 1000 you will find that both side-panels are removable by simply lifting a lever on the rear of the unit. When the lever is lifted a slide is actuated that runs horizontally inside the case and releases the door, which in turn can be lifted completely out of the way and stored elsewhere while you work on the inside of the chassis."
Reply to shortstuff_mt
Lever won't actuate. There must be a knukle or pvot "out of order". Therefore begins my problem of access.
Reply to Anonymous
Crowbar? :lol:
Neither side lever will lift so you can slide the side panel back?
Message edited by dndhatcher on 11-10-2009 at 01:51:12 AM
Reply to dndhatcher
how old is the computer, old age is a terrible thing, things get frozen and no longer work, larger use of force=destruction
Reply to number13
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Side panel removal
There are 1335 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
