Hi, first let me thank everyone here on Tom's for the valuable information that they've lent already. Over the weekend I received a few parts for my upcoming upgrade to a full custom loop. I opted to go with the XSPC Raystorm based on PureOC's review, the price and the fact that it comes with 2 blue led's which go with my current theme nicely.
http://www.pureoverclock.com/article1392.html
I also got the Koolance RP-452X2 ver. 2 reservoir and 2 Laing D5 pumps
And of course I have Danger Den water blocks
I am currently using a Corsair H100 and my cpu and gpu temperature while not bad, have room for improvement I feel.
I didn't put any load on the gpu but you can see what the idle temps are like. They are 10 degrees higher because of the dual monitors.
My plans now are to do a single loop using XSPC RX360 and XSPC RX120 radiators. But I haven't ruled out using a 140mm fan on the back of the case or on the bottom I have decided on the fans but I'm leaning towards the Yate Loons and I'd like to use compression fitting but I still need figure out how many I'll need.
