Ethernet cable max distance effective
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Ethernet cable max distance effective
I would like to operate a DSL computer about 400 feet away from the modem. What is the likelyhood of success??
Sponsored Links
Not good since the maximum length on CAT6 cable is 330'.
Reply to Grumpy9117
Make two segrments. Plug a long ethernet cable into the dls router and then into a small ethernet switch, plug one more cable into the switch and run it to your machine.
Reply to ntadmin101
PS, try to make the two ethernet cable lengths about half the total distance so that the signal on the line doesn't suffer attenuation, and make sure it isn't directly near any power supplies or lamp balasts.
Reply to ntadmin101
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Ethernet cable max distance effective
There are 1395 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
