Tom's Hardware > Forum > Homebuilt Systems > New System Build > New system build(first)
Forum Homebuilt Systems : New System Build - New system build(first)
APPROXIMATE PURCHASE DATE: Next 2-3 months buys parts at a time
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming
PARTS NOT REQUIRED: Monitors,Case,Power supply
PREFERRED WEBSITE(S) FOR PARTS: Newegg.com
PARTS PREFERENCES:
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Eventually
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS: Price range about 800-1000$
Sponsored Links
Depending on what PSU and case you have, something like this might work
Intel Core i7 860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core
http://www.newegg.com/Product/Prod [...] 6819115214
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel
http://www.newegg.com/Product/Prod [...] -_-Product
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop
http://www.newegg.com/Product/Prod [...] 6820227478
GIGABYTE GV-R577D5-1GD-B Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
http://www.newegg.com/Product/Prod [...] 6814125301
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal
http://www.newegg.com/Product/Prod [...] f3%20500gb
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA
http://www.newegg.com/Product/Prod [...] 6827118030
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve
http://www.newegg.com/Product/Prod [...] 6835103065
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
http://www.newegg.com/Product/Prod [...] 6832116754
That comes to just over $900.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
There is no point going i7 for gaming if you use such a slow graphics card (relative to what the core i7 can keep up with). I would drop down to a core i5 and put the extra money into a 5850
core i5 2.66GHz
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&Tpk=i5][/url]
Radeon 5850
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16814102857&cm_re=5850-_-14-102-857-_-Product][/url]
My changes would cost $25 more but would outperform the core i7/5770 by a lot.
Reply to Enzo Matrix
I agree with Enzo, if you can find a 5850. Hopefully in a few months the supply will have caught up with demand. A pair of 5770s is an option if need is urgent.
Reply to dndhatcher
^+1 to enzo and jbakerlent. Both did a good job. But enzo is right, an i5 and 5850 is a better deal compared to i7 860 and 5770
BTW, a quick neweeg search found me a CPU+RAM combo.
CPU+ RAM: (enzo matrix's suggestion + jbakerlent suggested RAM)
http://www.newegg.com/Product/Comb [...] mbo.286133
i5-750+OCZ Platinum 4GB (2 x 2GB) DDR3 1333 Model - OCZ3G1333LV4GK
Graphic Card: HD 5850 like what enzo suggested
Hard Disk: Same model as jbakerlent suggested but if you think you need more space go for this one(its 1 TB):
http://www.newegg.com/Product/Prod [...] 6822152185
Message edited by akash3656 on 11-11-2009 at 03:34:32 AM
Reply to akash3656
There are 947 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
