Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help! First build/No Monitor Display
Forum Homebuilt Systems : New System Build - Help! First build/No Monitor Display
OK im using a custom case,600W PSU,ASUS HDMI LGA 775 MOBO with onboard sound and video(Nv Geforce 9300),Intel 3.16 ghz CPU,Corsair x2 2GB DDR2 Ram,Hitatchi 750gb HDD,and Sony CD/DVD drive. I'm about 100% positive I connected everything right because I followed the motherboards manual. I have all the PSU connectors in,a 24 pin ATX and a ATX12 in the upper left corner. The SATA cables are in the CD and HDD and the 4 pin R,Y,B cables running from the PSU and fans are all connected except for 2 small 4-pins that have no open slots for. I plug in the computer and the fans start and the green power light on the motherboard starts up and I hear what seems to be the HDD and CD boot but the monitor hooked up with VGA shows no picture. It just bounces around with No Input Signal and then goes into sleep mode. Any help please?
Sponsored Links
check how you installed your video card. disconnect everything fromm it and try again.(but be sure before you try)
Reply to Sertac
It has onboard video.
Reply to tjmcvey2011
oh now i dont no what to say. install mobo drivers?
Reply to Sertac
I can't install anything until my monitor problem is fixed.
how about try on a diff monitor or the vga cable is broken?
Reply to Sertac
I've tried different VGA cables and even the HDMI output. My very tech advanced friend said it might be the PSU because it lets out a sort of burnt plastic smell at startup and its not a well-known brand. I called the company asking for a replacement.
There are 1041 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
