Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > [Solved] Water cooling noob needs some help
Forum Homebuilt Systems : General Homebuilt - [Solved] Water cooling noob needs some help
Best answer from shadow703793.
Hi guys, I've just bought the 800d corsair case for my computer and is planning on installing watercooling loop just for my cpu, as a result I'm looking for the components for this setup. I currently have selected the water block and the pump but needs some help on the choice of 3x120 radiator and I'm also open to any suggestions.
CPU Water Block: Swiftech Apogee XT
Pump: Swiftech MCP655-B pump
Radiator:
Reservoir (Not that important so I'm just looking for a pretty one lol):
Edit: found out what G1/4 mean (thread type) still open to suggestions on a decent radiator though. (I'm thinking about either the feser one 360 or black ice 420.
I really appreciate the help guys.
Message edited by yang on 11-07-2009 at 09:30:45 PM
If you haven't already read this read it: http://www.tomshardware.com/forum/ [...] ling-guide
As for the rads: http://www.xtremesystems.org/Forum [...] p?t=220593
For the res: get a Micro res. The RES IS important, esp. when it comes to quality. Last thing you want is a leaking res.
G1/4 indicates the barb size and thread type.
Sponsored Links
Best answer
Message edited by shadow703793 on 11-07-2009 at 09:36:32 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to shadow703793
There are 774 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 paesan won the Freshman badge
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
