CPU temperature help
I have an Intel Core i7-920 Processor, a Cooler Master Hyper 212 Plus Cooler, and a HAF 932 case.
I just built my computer two days ago, and I'm running Hardware Monitor. It reports that my i7 Core Temperatures range from 33-38C idle. I ran Prime95, and while stress testing, those numbers shoot up to the high 60s-low 70s.
I expected lower temperatures than this. I've checked ventilation inside the case, and all fans are spinning fine.
Any suggestions on what the problem might be? Thank you!
3 answers Last reply
More about temperature help
  1. Check that the 212 is installed correctly.
    Yeah, I'm pretty sure it is. I used the thermal paste that came with it. Would having used Artic Silver instead have made a difference?
  3. I don't think. My temps are the same with a stock cooler and an TT V9. Remove the 212 and install again.
CPUs Intel i7
