T TFJ4 Distinguished May 8, 2010 1 0 18,510 May 9, 2010 #1 When I plug in my 4 pin power fan header to the motherboard my computer receives no power, when I unplug it then it works fine. Thoughts? GIGABYTE GA-P55A-UD3P Motherboard
ronss Distinguished Jun 16, 2009 230 3 18,695 May 11, 2010 #2 you have a cpu fan 4 pin hearder, and sys fan 4 pin header...are you sure the cpu and the 4 pin header are in the correct places.... also...are you sure the black wire is oriented to pin 1 on the fan header..that is the ground Upvote 0 Downvote
