Power help
Forum Homebuilt Systems : General Homebuilt - Power help
Im running 2 ati 4770 in cf with a little Thermaltake tr2 450psu
the q is how can i tell if my system needs more power?
i play cod4 just fine
this is what my system is
785g gigabyte mobo
2x sapphire 4770 videocards
amd 550 cpu oc@3500
2x ddr2 oc 8500 ram
1 dvd
1 hd segate 7200 500gb
1 ac ol 64 freezer cpu cooler
3 120 fans
is there any software that can tell me if im starving my system
i know i should get a bigger psu but if my system runs fine y should i?
any thoughts would be great
Sponsored Links
You can't measure it with software, but your system doesn't draw more than 300W. http://www.thermaltake.outervision.com/Power
Reply to GhislainG
Your system will freeze or shut down if it needs more power. Unless or until that happens, enjoy :)
Reply to Twoboxer
thanks for the link
Reply to roddy
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Power help
There are 1230 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
