Tom's Hardware > Forum > Graphic & Displays > ATI > ATI 4850 Fan Speed Control
Forum Graphic & Displays : ATI - ATI 4850 Fan Speed Control
If I change the fan speed on the video card using the manual fan control on the catalyst manager will it fluctuate when the card gets really hot. What I mean is that when it is on default there is an automatic fan speed that will fluctuate the fan depending on how hot it gets. Will this happens if I manually change the fan speed or will it stay on the percentage that I set?
Sponsored Links
If you manually set the fan speed it will not fluctuate. Why do you want to manually change this? Are you overclocking? I've used ATI Tray Tools in the past to change my fan profile. This way you can increase the fan speed at certain temps to keep it cool yet quiet when not gaming.
Reply to jay2tall
My idle temps seem way too high at 77C.
Reply to ragsters
Do you have enough case airflow? Idle they should not be that high. What model 4850 do you have?
Reply to jay2tall
I have about 8 120mm fans blowing. The video card is the reference design with single slot cooling. The fan speed at idle is only at 14-16%.
Reply to ragsters
Screw it i wrote another post decided it was not worth it.
Your temps are fine and not going to do any harm however most people choose to manually set the fan to a higher rpm. The fan will only spin up if the gpu temp approaches a certain level.
Your best bet is to creat one profile for gaming, and one for desktop.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
Thanks strangestranger that actually makes me feel a lot better.
Reply to ragsters
There are 1294 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
