Need Power supply info
Hi all, I'm trying to find some information about these 2 power supplies, I've read they're great in some places and horrible in others, any input you can give me would be most appreciated.
These are the 2 Im looking at.
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10125753&catid=
Rocketfish 900W Power Supply (RF-900WPS)
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10109734&catid=
Rocketfish PC Power Supply (RF-700WPS2)
Current system specs: http://www.xfire.com/profile/insomniak604/#game_rig
I need the power supply today if possible, so thats why Im going to futureshop, if you can find any other computer stores open on a sunday in chilliwack BC, by all means, send me a link :P
Thanks, InSoMnIaK604
5 answers Last reply
More about need power supply info
  1. Don't know about the 900 watt unit.
    The 700 watt unit is "peak" rated, it's built on a CWT 550PSH platform ( same as the Corsair 550 ) and is more than enough for your specs.
  2. The Rocketfish 700 watt power supply is made by Huntkey according to Jonny Guru.
    Rocketfish? Isn't that a Best Buy house brand?
    Found the old thread. Rocketfish and Dynex are both owned by Best Buy. Is Future Shop the Canadian version of Best Buy?
    Here's a link to a technical review of the 700 watt power supply over at Hardware Secrets:
    http://www.hardwaresecrets.com/article/556/1
    Adequate but not exactly a stellar performer.
    The review is for the original "WPS" Rocketfish, the OP is looking at the "WPS2"
    Rocketfish , like other vendors , sometimes change's oem's.
    Here's a couple of link's for you
    http://www.80plus.org/manu/psu/psu_reports/SP119-CWT-PSH550V-D-Report.pdf
    http://www.80plus.org/manu/psu/psu_reports/ROCKETFISH_RF-700WPS2_ECOS%20630%201_550WT_Report.pdf
  4. Dang blasted conflicting information! :bounce:
  5. Thanks for all of the info guys, I decided to go with the 700watt - I'm now back on my computer now :D
Power Supplies Computer Components
