What do you mean by that?Absolutely not. The ALC is a closed system so adding an additional loop/block will not be feasibly possible. Domino ALC should not even be considered a true water cooling system since it's performance is often overshadowed by the top air heat sinks.
It is an attractive solution for those who do not have the dimensions or appeal for a large heat sink.
