Atx 12v power connection 790FX-GD70
szbxa
199
welcome to the forum.
though you didn't say your budget, but i can see through the GD70 and the 965 that you do have money to spend. for the normal usage and gaming, you need nothing more that 4GB and you can pick some ddr3 1600 memory with lower latency. if you need extra amount, just go for them. i suggest you the corsair dominator for the performance and reliability.
