Solved
Help Installing multiple fans!
Hello,
I will be building a new computer and I need a way of installing about 12 fans, but my motherboard only has 2 connections.
How would I plug more in?
Do I need something extra?
If so, what would you recommend?
Thanks in advance!!
3 answers Last reply Best Answer
More about help installing multiple fans
  1. Best answer
    Those would be molex connections, however I recommend this: http://www.amazon.com/Scythe-KQ02-BK-Kaze-Channel-Controller/dp/B00559FHZY amazon seems to be the only one who has them.
  2. Why do you want to install 12 fans? I mean, any modern gaming case will have adequate cooling with the 3 or 4 built in fans.
  3. Best answer selected by Yogi6994.
Heatsinks Computer Motherboards Overclocking
