Hi i have a GA-MA770 DS3 Rev1 Gigabyte motherboard and just flashed the BIOS with that QFLASH BIOS Utility... Its the most recent BIOS version and i downloaded it from the Gigabyte website.. the Flash went well, but when i turned on the computer after completion and entered into the new BIOS, none of the bios settings work in the submenus! They are just greyed out!. The only option available to change is the boot priority.. The website said the new bios version was "beta" but cmon it cant be that bad that i cant even change settings eh?. The new bios version i just updated to is called "MA770DS3.F8f" and heres the link to where i got it from:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=2722
I downloaded the newest Bios version there.
Help me out? any suggestions? or do i have to reflash back to an older version and risk destroying my motherboard, cause i hate flashing.
