Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Sli xfx 9800 gtx+ and 610w power supply, enough?
Forum Graphic & Displays : Graphics Cards - Sli xfx 9800 gtx+ and 610w power supply, enough?
Hey everyone, i currently have an xfx 9800 gtx+ in my system and im planing to sli... but i am unsure if my power supply is strong enough so can u guys help me in deciding whether or not i am eligible for sli.
currently i have a pc power and cooling 610w silencer PSU with max of 49Amps on a 12 volt rail. Ive read that to sli these card u should have atleast 750watt PSU! So do u believe i will be able to run both my cards? Also i will be using them for gaming so not just surfing the web. Can they run with a 610 PSU while on full load?
thxs
Sponsored Links
You should be ok if your PSU isn't very old (aging capacitors).
I've read reviews that say a system with two 9800GTXs in SLi draws up to 500watts...yours is a 9800GTX+, and should be slightly more power efficient. Just make sure you have 4xPCIe connectors to run the two cards.
Nvidia recommends a 750watt PSU but a minimum of 45amps on the 12v rail (which is far more important than the watts). You have a quality 610watt PSU with more than enough amps, which is better than most 750watt no-name brand PSUs out there.
Message edited by Bluescreendeath on 11-16-2009 at 11:28:11 PM
Reply to Bluescreendeath
There are 477 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
