Tom's Hardware > Forum > Homebuilt Systems > New System Build > MicroATX power supplies
Forum Homebuilt Systems : New System Build - MicroATX power supplies
how high do mATX power supplies run in watts
Sponsored Links
I'm not sure what you are actually asking, mostly becaise many microATX cases use full ATX PSUs. There is no difference from an electrical standpoint, it's just size and mounting holes.
The highest wattage I found on newegg was this 550W:
http://www.newegg.com/Product/Prod [...] 6817338038
But really, at that price you would be better off getting a new case and a better PSU such as the OCZ 500W SXS
http://www.newegg.com/Product/Prod [...] =OCZ500sxs
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Yeah, if you can try and buy a mATX case that can use a standard ATX PSU.
Here's an example:
http://www.newegg.com/Product/Prod [...] 6811133045
Here's the specs:
http://www.thermaltake.com/product [...] 000bns.asp
On the other hand if you already have a mATX case, then your hands are tied...
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
There are 571 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
