Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Upgrade recommendations for existing system
Forum Homebuilt Systems : General Homebuilt - Upgrade recommendations for existing system
Hello,
I have a system I built back in early 2007, that I recently upgraded to windows 7, and I'm looking for advice on how to improve my performance. I appreciate your feedback. It's been a while since I've looked at parts, so I'm not sure where to start, or what will work with my existing system listed below. Be it RAM, CPU, graphics card, MOBO, I appreciate your time to respond:
APPROXIMATE PURCHASE DATE: within a month
BUDGET RANGE: negotiable
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: heavy photoshop, web design, possible future windows media system.
PARTS NOT REQUIRED:
* 1 x COOLER MASTER Centurion RC-534-KKR5 Black Aluminum & Mesh bezel, SECC chassis ATX Mid Tower Computer Case 400W Power Supply - Retail
(replaced PSU above with this since order)
*1 x PC Power and Cooling S61EPS 610W Continuous @ 40°C EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply compatible with core i7 - Retail
* 1 x GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
* 1 x BFG Tech BFGR76256GTOCE GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card - Retail
* 1 x Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 65W Dual-Core Processor Model BX80557E6400 - Retail
* 1 x OCZ Platinum 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2P8002GK - Retail
* 2 x Seagate Barracuda 7200.10 ST3320620AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive (Perpendicular Recording Technology) -Bare Drive
* 1 x HP 18X DVD±R DVD Burner With LightScribe, 12X DVD-RAM Write Black IDE Model HP940I LightScribe Support - Retail
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: indifferent
OVERCLOCKING: no
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS:
Message edited by phendyr on 11-10-2009 at 04:55:49 AM
Sponsored Links
I think you are fine except you may want to look into getting a 4850 or maybe lower just to boost performance though you may not notice any difference
Reply to wsupduck
Your motherboard should support a quad core, so it could be worthwhile to spend a few bucks on a q9550 or q9650. Also maybe look into a couple gigs of RAM (if you installed 64 bit), as that will help you out a bit as well. Maybe even a 48xx series graphics card.
------------------------------ -Kevin
Desktop: Q9400(stock,lapped,SpinTechQ)/Intel DP43TF/VTEK 4850(512)/8GB DDR2 800Mhz/X-Fi Titanium Pro/Liteon BD-ROM/Velociraptor/Windows 7 Pro 64-bit
Laptop: Little Toshiba Satellite (M305)/T6400/4GB DDR2 800Mhz/Windows 7 RC 64-bit (for now
Reply to buwish
thanks for the feedback, I'll look into pricing on the ram and other bits. hoping to put some freelance money to good use!
Thanks again, great site & people.
Reply to phendyr
Just looked up my mobo, and it does support quad core :wahoo: the RAM it supports is:
1. Supports DDR2 800/667/533 memory
2. Dual Channel architecture support up to 8GB by 4 DIMM slots
will have to look into some options for that, since the RAM I originally purchased has been discontinued I guess.
Reply to phendyr
There are 1192 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
