Tom's Hardware > Forum > Homebuilt Systems > New System Build > Medicore gaming build (~$800 + spare parts)
Forum Homebuilt Systems : New System Build - Medicore gaming build (~$800 + spare parts)
APPROXIMATE PURCHASE DATE: Around Thanksgiving in 2 weeks
BUDGET RANGE: ~$800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Video/Photos, Web browsing
PARTS NOT REQUIRED: Keyboard, mouse, speakers, monitor (24" BenQ FP241VW), PSU (OCZ 1000W ProXstream, GPU (8800gtx), HDD (500 and 750 WD), DVD/Blu-ray drive, OS (Vista Ultimate 64 bit)
PREFERRED WEBSITE(S) FOR PARTS: newegg, but anything will do
PARTS PREFERENCES: Intel CPU
OVERCLOCKING: Yes
SLI OR CROSSFIRE: either one is fine
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS:
Case: Still undecided, but I'm leaning toward CM HAF 932 ($139.98). Also wouldn't mind mid ATX tower.
http://www.newegg.com/Product/Prod [...] 6811119160
CPU: Intel Core i7 920 ($199 from nearby Microcenter)
MOBO: Still undecided, but looking at EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE ($229 - $20 MIR). Still want a cheaper alternative though.
http://www.newegg.com/Product/Prod [...] 6813188049
RAM: Not really planing to overclock these, so almost anything will do. Looking at OCZ Gold 6GB (3 x 2GB) DDR3 1600 ($149.99)
http://www.newegg.com/Product/Prod [...] 6820227365
CPU cooler: Very tempted to get these after reading all the reviews: Looking at CoGage True Spirit + Thermalright Bolt-Thru Kit ($50 shipped)
I'll be also upgrading to Window 7 when my brother buy his laptop around thanksgiving as well as upgrading my 8800gtx some time next year.
Thanks for all your time guys.
Sponsored Links
hey man!
you don't need i7 920 for gaming..it's overkill if you ask me..
i7 920 is for intensive cpu demanding programs such as CAD or designing/editing programs..
an i5 750 is more suitable for you.
by the way, you don't need to upgrade your video card?
Message edited by overshocks on 11-10-2009 at 06:50:41 AM
------------------------------ You can select me as Best Answer
e6400 oc'd 3.2ghz,CCF cooler
3870x2, p5k/epu
750watts psu, antec 900
Reply to overshocks
i5 750 route...
>MOBO+RAM 30 dollar discount
http://www.newegg.com/Product/Comb [...] mbo.289943
>CPU
http://www.newegg.com/Product/Prod [...] -_-Product
>Heatsink
http://www.newegg.com/Product/Prod [...] 6835103065
>Case
but if you go for the i7 920 route it's fine, since you have mircocenter near you...
i7 920 route...
ram (tighter timings than the ones you've picked, 1333mhz, the performance is similar so either one is fine)
http://www.newegg.com/Product/Prod [...] 6820231230
or ram
motherboard - supports sli and crossfire...
http://www.newegg.com/Product/Prod [...] 6813131359
>Heatsink
>Case
Message edited by overshocks on 11-10-2009 at 06:53:33 AM
3870x2, p5k/epu
Reply to overshocks
Well after reading some reviews on 1156 socket MOBO, it seems there's quite a few complications with them. So, I think I'll go with 1366 route for now..
Reply to purostaff
Definitely go with the HAF 922 instead of the 932 like Overshock suggests.
The only cheaper good x58 motherboard is the ASRock x58 Extreme ($170).
Reply to dndhatcher
agree, but if he's looking for a better overclock then the asus mobo i suggested. if he just wants a i7 920 system, without much features. definitely asrock x58 extreme.
Message edited by overshocks on 11-10-2009 at 10:51:29 PM
3870x2, p5k/epu
Reply to overshocks
There are 771 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
