Will an antec earthwatts 500 power a radeon 5870?
Ok so I have a dell 435mt and I am about to put in a Powercolor LCS Radeon 5870.
My system specs:
core i7 920
12 Gb ddr 3 1066
2 Sata HD's
2 disc drives
SB xfi xtreme
ATI says the minimum psu for the 5870 is 500, which I have, but this card is liquid cooled does that make a difference?
I feel like I am going to be teetering on the fence at full load. What do you think?
Related ressources
sonoftherooshooter said:
Thanks for the responses. Though I have heard that Corsair PSUs aren't compatible with Dell MBs
First I heard of that. I was under the impression that all consumer PSUs and Mobos conform to standard connections and operations.
If true, that's a Dell issue, not a Corsair issue and would likely be an issue with dozens of PSU makers.
Corsair PSU's are made by Seasonic. Whom also make their own brand and also PC Power & Cooling PSU's.
And, JofoMang, Seasonic also makes some Antec's...so according to this, you can go wrong with an antec.
But as I said, ATX PSU's are wired to a certain spec regardless of wattage. So if this is an issue with 360+ watt ATX PSU's, DELL needs to make it known.
Just found this on Wiki:
"Issues with Dell power supplies
Older Dell computers, particularly those from the Pentium II and III times, are notable for using proprietary power wiring on their power supplies and motherboards. While the motherboard connectors appear to be standard ATX, and will actually fit a standard power supply, they are not compatible. Not only have wires been switched from one location to another, but the number of wires for a given voltage has been changed. Thus, the pins cannot simply be rearranged.[2]
The change affects not only 20-pin ATX connectors, but also auxiliary 6-pin connectors. Modern Dell systems may use standard ATX connectors.[3] Dell PC owners should be careful when attempting to mix non-Dell motherboards and power supplies, as it can cause damage to the power supply or other components. If the power supply color coding on the wiring does not match ATX standards, then it is probably proprietary. Wiring diagrams for Dell systems are usually available on Dell's support page."
http://en.wikipedia.org/wiki/ATX
Hmm, from the short amount of sleuthing I did (i read the link he provided), it didnt work with a Corsair 650TX, but did work with an Antec 650w earthpower. I don't know enough about the PSUs to say whether or not they are from the same seasonic part, but if that link is to be trusted at all, the Antec worked when the corsair wouldn't.
I actually tried an Ultra 750 watt PSU a few months ago and it killed the MB. Yikes, dell replaced it but still... I read a thread where someone had actually successfully installed a Thermaltake 850W TR2 RX PSU in this Dell 435mt and had no problems.
http://www.tomshardware.com/forum/266614-33-upgrade-del...
I'm more than likely going to get this power supply, because at this point, it seems to be my only viable option. But if the wiring issue is true, which I don't doubt that it is for some Dell computers, I wouldn't even know what to look for, i.e. wire arrangement, order, etc.
Is there a sure fire way to know if a certain PSU is going to fit this proprietary MB just by checking out the wires?
Ask the community
