My computer has been acting up recently. When I push the power button on my computer, you hear the usual sounds of a computer attempting to boot up. The fans start whirring, you can hear the hard-disk making its usual churning noise, but the fan on the motherboard itself seems to spin up -- then stop. Repeatedly.
The only way around this problem is to either repeatedly power cycle the computer, or pull out the AC Cord, release the remaining energy, plug it back in, and start up the computer.
The symptoms really seemed to be like a power issue, so I did the most logical thing to me -- replace the power supply.
It didn't work however. The same symptoms remain. Can I safely assume that it is a problem with the motherboard now? Are there any simple tests I can run to further determine the problem?
