Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Problem with Rig [Freezing]
Forum Homebuilt Systems : General Homebuilt - Problem with Rig [Freezing]
Hi all.
Im having an issue with my computer... it is randomly freezing while playing and lisning to music.
It started happening some time ago but it could be only coincidense but now its becoming impossible.
Today while i was seeing a movie from my favorite serie it freezed 3 times... the symtoms begins like the sound stops and 5 secs later puff FREEZE but it unfreezes if i.wait like 3~5 mins and it comes back to life....
My Computer Specs are thease:
CPU:Core i7 920 @2.66 Default
Ram:1*6 Corsair Dominator 1600mhz
GPU:Asus EN GTX295
HD's:Maxtor 320Gb / Hitachi 160Gb / Seagate Barracuda 1.5Tb
Sound:Auzentech X-Fi Forte 7.1
Mobo:Gigabyte EX-58 Extreme
Case:CollerMaster Haff932
PSU:Corsair TX850W
SO:Windows 7 x64 Ultimate
so please someone give me a hand im not getting where the problem is...
Cumps.
Sponsored Links
Freezing problems are often RAM related. Which 1600MHz 6GB Corsair Dominator kit do you have? All these match that description.
http://www.newegg.com/Product/Prod [...] 00&x=0&y=0
Have you manually set the RAM speed/timings/voltage to the manufacturer's specs in the BIOS? Have you run Memtest86+ overnight to test for RAM errors?
What are your idle and load CPU temps?
Reply to shortstuff_mt
- 0 +
i just reset the bios so the speed is @ 1066mhz default values from bios and im only running with 2 sticks and it has freezed again i used furmark ,prime 95 and windows media player playing music and it frozed like 20 secs later when i closed the programs and came back to life as i said before.
My cpu temps are really good with 100% are at 45º it has a noctua 12p on it... more then enough.
My reference of rams are:
TR3X3G1600C8D 8-8-8-24 1.65v
Reply to xiterx
I would manually set the RAM to 1600MHz with 8-8-8-24 timings at 1.65v in the BIOS. I would then run Memtest86+ overnight. None of the programs you are using to test are designed to detect faulty RAM.
- 0 +
i forgot to say that im using dual screen too don't know if it makes something diference. one o 22" using 1680x1050 and the other of 19" using 1280x1024
Reply to xiterx
- 0 +
i should put all the rams and let all the night? and a little thing is that on the bios the voltage only can make me choose 1.64v or 1.66V dont know why....
Reply to xiterx
1.64 should be fine. I would run the test on each stick then together.
------------------------------ P55-UD4P / i5 750 @ 3.6 180X20 / GSkill 1600 @ 1420 7-7-7-22 / WD Black 640 / HD 5850 / Corsair 750 / Win 7
Reply to niklas_13
- 0 +
i just got this http://img4.imageshack.us/i/img0013vm.jpg/ in so little time what should i do ?
Message edited by xiterx on 11-11-2009 at 03:24:56 AM
Reply to xiterx
Thats not good you should beable to run that program all day without errors, Maybe think about RMA the ram.
Reply to niklas_13
- 0 +
i bought 2 packs of 1*3 but i dont know wich one is ... is the ram on the slot near the cd drives or the one near the cpu ?
Reply to xiterx
Your ram should be to the right of the CPU fan.
Reply to niklas_13
- 0 +
i taked all the newst pack of rams that i got and its now testing with the other pack, when i took the ram near cpu i still got this error http://img40.imageshack.us/i/img0017ll.jpg/
Message edited by xiterx on 11-11-2009 at 02:36:53 PM
Reply to xiterx
- 0 +
i just went and download the new memtest 86 but i only can run it with 3 Gb of each pack of 3 Gb's ... can´t understand why but i just made it run a pack at a time and both made a sucessful pass... can someone help me just to know if i doing something wrong please.
Cumps
Reply to xiterx
Do you mean it's giving errors when all six sticks are in, but if you just use three at a time, none of the six sticks gives an error?
That's odd, but I do know that when you fill all your RAM slots, sometimes the RAM will take more voltage to run. Don't know if that would affect memtest results, though. Maybe someone with more background on the subject can shed some light.
Reply to capt_taco
- 0 +
i think im having like false positives dont know but in memtest86 3.5 6sticks is a now go for test but on memtest86 3.4 he can do it but i really think its a false positive ...
Reply to xiterx
- 0 +
i think i solved it for now.
was a bad firmware from seagate .... for now i didnt got a freeze at all
cumps
Reply to xiterx
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
