Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > Front panel sound from MB or sound card?
Forum Motherboards & Memory : Motherboards Front panel sound from MB or sound card?
Hey,
In the front of my case, I have a plug for headphones, which I have connected to the motherboard. I also have an older sound card (Audigy 2) that I've installed in a PCI port.
I was wondering if the sound I'll be getting when having headphones plugged into the front panel is from the sound card or the onboard motherboard sound?
I would imagine the motherboard isn't smart enough route the sound from the sound card, but I figured I would check with the experts.
Thanks in advance!
Reply to neubert
connect it to what ever sound card your speakers are connected to.
Reply to Emerald
- 0 +
The thing is that my sound card did not have a connection that fit with the cable. It may be because it is an older card?
It only had a 3-pin connector, whereas the connector I put in the motherboard was 4x2 pins (with one corner missing a pin) - if I recall correctly.
It is not a big deal, I don't think I will be able to tell a difference with the sound, but I got curious.
Message edited by neubert on 05-13-2010 at 05:45:44 AM
Reply to neubert
There are 1950 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Do I need a new motherboard?
By smorizio, 1 hour ago:
you waste your money unless you where getting an overclock cpu. any new mb with the same...
Best offers
Top experts
