Hi polorsport,
it seems like your problem was similar to mine, except i had a 'click-to-death' hdd, which was proper annoying. Try putting your hdd in an antistatic bag, then put the antistatic bag in a zip-it polythene bag & chuck it in the freezer for 4 hours. After 4 hours, install it in your system pronto & transfer your most important files 1st. Bear in mind, you only have around 20-30 mins b4 it starts playing up again.
I did this with my click-to-death, clicking hdd & it worked!! - i was able 2 backup my most needed files b4 i dismantled it for tha magnet inside it
(which was fun after all tha grief it gave me). Give it a try; it's no joke; it really works in most cases. Google "freeze hard drive" if you think i'm joking.
Good luck
btw, i'm impressed that your system is pretty powerful. SSD's are dread, super fast, but low capacity. I'll get 1 (or 2) when tha price falls a bit
polorsport :
My setup:
OS
windows 7 Pro x64 SP 1
CPU
I5 2500K
Motherboard
ASRock Z68 PROFESSIONAL GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Memory
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DD, G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL. 16 gb total
Graphics Card(s)
Evga 580 gtx Superclocked sli reference Evga 580 gtx
Sound Card
N/A
Monitor(s) Displays
Acer HN274H 3D Vision-ready LCD Monitor
Screen Resolution
1920x1080p
Hard Drives
x2 Western Digital Caviar Black WD2001FASS 2TB 7200 RPM 64MB
Crucial M4 CT256M4SSD2CCA 2.5" 256GB SATA III SSD
PSU
Antec High Current Pro HCP-1200 1200W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Case
COOLER MASTER HAF 922
Cooling
Cooler Master RR-B10-212P-G1 Hyper 212 Plus
Keyboard
Logitech K750 solar panel
Mouse
Logitech G400
Internet SpeedEdit Value
25mbps up/down
