BAD power supply??
just look at the voltages in the pic could this be causing me my overclocking woes just looking at those voltages something isn't right...
[url=]
2 answers Last reply
More about power supply
  1. Check Voltages from bios.
    Softwares don't monitor correct voltages.
  2. Don't worry about the two negative voltages. At least one of them (the -5volt line) is clearly bogus. Starting from several years ago, PSU's don't even have a -5 volt output. And a lot of the Windows software for monitoring PSU outputs do not handle negative voltages well.
    Check the PC Health section of the BIOS or measure with a digital multimeter. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: +5 volts always on. The gray wire is really important.
    It should go from 0 to +5 volts when you turn the PSU on. CPU needs this to boot.
Power Supplies Overclocking Components
