Problem with startup
Hey guys
I don't know if this is the right place to post this but i am guessing is related to this.
So i have been getting problems trying to get my OCZ ram to set the right timings but i couldn't and finally ended up getting another brand G SKILL F3-10666CL9D-4GBNQ.
but something weird has been happening since then.
everytime i turn off the computer for a while the system can't load into windows without getting the BSOD and after a few tries it will load up. I have ran both memtest and prime, both passed hours of testing.
here is my system specs
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
Antec EarthWatts EA650 650W
Thematek heatsink
Two HIS H485FN512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP
4 answers Last reply
More about problem startup
  1. Hello and welcome to the forums :)
    What is the exact BSOD error ? go to "Advanced system settings",then in the "Startup and recovery" section click on settings and uncheck "Automatically restart",now when you get BSOD,you can simply read its error,so do it and tell us what exactly the error is
  2. Doesn't look like your memory is on the qualified vendor list for the M4A78T-E MB. See http://www.asus.com/product.aspx?P_ID=cf8IZzbU4m6GHKnW.
    However the F3-10666CL9D-4GBPK memory is and its Bios timing is: (1333-9-9-9-24) voltage 1.65. So you could try that.
    Also double check everything inside your box. Memory clipped in fully, nothing creating shorts on the MB etc.. and yes, BSOD code would be helpful.
  3. i checked the ram alrdy...i even took it out and switched it around
    also on that vendor list i don't know why there are triple channel rams there...can those work with my board and system...
    my error codes are as follow
    0x0000000a
    0x000000be
    0x0000007e
    0x000000d1
    i didn't right down the bracket stuff...should i do that too...
  4. Do you have the BSOD error message as well?
Asus Motherboards
