Hey Guys,
I'm currently overclocking my FX-6200 on an Asus Sabertooth 990FX. I have corsair vengence memory running at 1866Mhz and a Sapphire 6870 graphics card all being powered by a Antec 750w bronze rated PSU.
currently my overclock is 4.6Ghz @ 45C on stock voltage with a 23x multiplier. I have all the power options in my bios turned to extreme as far as power is concered and all the other features (such as cool n' quiet) disabled. When I bump up to 23.5x Multiplier I BSOD and increasing the CPU bus speeds usually results in my 3 or 4th core failing within 20 minutes of a prime95 test.
Unrealistically I'd like to see 4.9-5Ghz and realistically I'd like to push for an extra 200Mhz stable (4.8Ghz) for a full 1Ghz OC. let me know if you guys have any thoughts, tips, hints or if these chips don't respond well to CPU bus speed increases and this is all I'll get.
honestly, I'm not sure if this speed was granted by my water cooling or not but I'd like to push the limits of that too, I believe these chips top out at about 63C but I'm not 100% on that... Prime95 is programmed to shut down at 60C to be on the safe side but hasn't gotten above 52C
