Corsair Obsdian 800D Case Mod Project
This custom Corsair Obsidian case project is for Canada's premiere hardware review site, "Hardware Canucks"
Here is some of the Case Mods & Supplies that will be used in this project
Acoustical Sound Proofing Sheets for your PC
http://www.mnpctech.com/colored_acrylic_sheet_casemod_window.html
U-channel molding, http://www.mnpctech.com/UChannel.html
I'll be using these pop-rivets for computer cases, http://www.mnpctech.com/Pop_rivets_for_computer_case.html
Most Computer Chassis will accept 1/8” diameter size Pop rivets.
Hmmmm.... debating about the factory feet
Sorry, these factory feet MUST GO!
I just wanted to see how this rad grill looked on the Obsidian, thats all
I see some Chieftec cues in the manufacturing. The Obsidian reminded me of the old Alienware ALX chassis. The texture of the Matte Black finish as well
The front bezel assembly comes off easily
SATA Hot swappable HD bays
I'm not a fan of the Corsair "sail" window design, I'll take it Squared for this one..
After a quick alteration! Square is better in this case.
The Motherboard tray will slide out, but you must remove 3x screws and drill out 3x pop rivets, located in the rear (shown in photo) It would have been nice if the rivets were screws instead.
Maybe you've debated about painting your Obsidian chassis. This is how I remove the plastic "Tool-less" 5.25 bay sliders without breaking the tiny plastic tabs inside. These tabs hold the slider onto the bay. You will need to bend the metal tabs as I illustrate here. You need to first file down the sides of the metal tab, so it will sit flush when you flatten it (not shown). I will then tap the metal tab with a flat head screw driver using a rubber mallet.
Keep in mind if you're painting your chassis, you will need to bend the metal tabs back into place after re-installing the sliders. Doing this will likely chip your new paint! so you'll have to re-touch these tabs again. After considering this thought, I've decided to eliminate the sliders altogether. Corsair has left the option of fastening in your optical drive the traditional way with screws. Only 2 screws per side, but thats sufficient enough!
100 answers Last reply
More about corsair obsdian 800d case project
  1. Looks good so far. Did you have to make a new window to fit in after making the side view square? Also, are you going to need to remove the black matte before painting it to make sure everything fits when reassembling the case?
    Keep up the good work and keep us posted!
  2. Thanks, Yes, I will have to make a new window now.. The factory finish might be corse enough to use for base coat
    The Obsidian allows a 360 size radiator installation without any modification, but what fun is that? I just happen to have a new Hardware lab's Black Ice 420 GTX (3x 140mm) Radiator here. I'm altering the top panel of the Obsidian to accommodate it! The wider 420 rad requires surgery to the 5.25 Optical drive bay. You remove the 5.25 bay by drilling out all of the pop rivets on the front of the Obsidian chassis.
    Supplies & Tools I used for this "photo illustrated" installation
    Mnpctech 420 Radiator Grill from performance-pcs used for measuring the location.
    You can also use these Radiator Mounting Templates
    Masking Tape
    Any Rotary tool like a Dremel
    Jigsaw with 18 TPI or higher metal cutting blade
    Center punch
    Power Drill with 3/16" drill bit
    12" Measuring Square
    12x M4 x 35mm size socket head machine screws length of mounting screws on what fan/rad set-up works best for your system.
    3x ??????? brand 140mm cooling fans (to be announced)
    more to come!
  3. Nice, just wanted to thank you guys for all the great videos on YouTube, etc. You made me take another look at my Dremel ! The possibilities are endless. Greetings from Cape Cod , MA, USA
  4. Thank you, awesome avatar btw!
    I grabbed wrong screws on the way to the shop for the rad/grill/fans, so I'll have to continue on it tommorrow.
    Here is the revised file for the 140mm fan grill
    80mm Honeycomb Acrylic Fan Grill, http://www.mnpctech.com/Computer_Fan_Grills_Laser_PC_Fan_Grills.html
    I also plan to sleeve the Power Supply Cables with one of these custom white PSU cable sleeve kits
    24 Pin ATX Power Supply Removal & Molex Pin Extractor Tools when custom sleeving your Power Supply and Molex connectors.
    http://www.mnpctech.com/24_pin_PCI_ATX_PSU_power_supply_sleeve_removal_tool_extractor.jpg
    http://www.mnpctech.com/molex_pin_male_female_sleeve_tool_extractor.jpg
    http://www.mnpctech.com/GrommetWb1.jpg
    I'm using these Fan vibration rubber grommets to mount the fan
    http://www.mnpctech.3dpixelnet.com/picture_library/holesaw_5.5_size_for_140mm_cooling_fan9r.jpg
    I use a Micro Flat head screw driver to install the Fan vibration rubber grommets.
    http://www.mnpctech.com/Uchannel1.jpg
    Give the fan hole a professional look by installing
    U-channel rubber trim
    http://www.mnpctech.3dpixelnet.com/picture_library/holesaw_5.5_size_for_140mm_cooling_fan9t.jpg
    The U-channel molding will cover any mistakes or scratches made while cutting the fan hole.
    ]#10-5/8 Black cooling fan screws
  5. Nice fan grill design. Since it's for Hardware Canucks shouldn't it be Canadian Red?
  6. ^ That's what I was thinking too. And case should be all read & white.
  7. red with white accents! :D
  8. Thats just Green because of our Cad software.. hehe
    I'm removing the factory perforated grill to help improve airflow. This mod will also cut down on airflow noise from your cooling fans.
    To avoid creating scratches in the factory finish, apply masking tape over the area you're going to be cutting.
    The Obsidian uses "doomed" pop rivets, which doesn't allow the grill to sit flush. I will swap these out to the more flush "countersunk" pop rivets.
    Use 1/8" size drill bit to remove the factory pop-rivet
    Pop-rivet Tool (Gun)
    Tracing the inside diameter of the grill opening.
    Using the first 140mm fan grill design, to mark off the location for the hole.
    Using Dremel 1.5" cutting wheel to make initial cut into the chassis
    Using Jigsaw with 18 TPI metal cutting blade
    The case panel lip was removed with the Dremel to fit around the grill.
  9. Next I need to get the rad fitted properly so I can get everything off to paint soon.
    The rad grill pictured here is a 420 (3x140mm) it's machined from 3/16" 6061 aluminum, and anodized Black. It has fully adjustable inserts.
    Different sizes and finishes of these rad grills are available from performance-pcs and they ship worldwide!
    Using 3/16" drill bit to make mounting screw holes.
    This is how my initial cut out for the radiator looked.
    I attempted to install the grill/rad/fans, but the remaining "recessed" material wouldn't everything to fit together flush without using different size screws. I then decided to modify the panel further by removing the remaining honeycomb perforation and flatten the lip.
    The recessed center portion of the top panel helps reinforce rigidity. However, the chassis is steel, so I don't believe it was too detrimental to do this. I think it would have been fine to have left the panel flat. I would consider designing the panel perforations in a Obsidian 2.0 with optional for both 360 or 420 size radiators.
    Flattening the fold was done by turning the chassis upside down on the bench, and flattening the folds with a rubber mallet. Now I could use M4 x 30mm length machine screws to attach everything together.
    I installed the three included 140mm fans from Corsair to pre-fit everything.
    All of the 140mm fans will be replaced by another brand to be announced.
  10. oh man i wish i could mod like this. I Havent ever modded before but i plan to when i get my new case lol.
  11. Everyone has a first time for everything. Glad to hear you're gonna try it :)
  12. We finished the HC logo inspired window frame today. This was made from 1/8" thick aluminum.
  13. very nice!
  14. Thank you Johnny!
    We finished the custom HC logo 3x140mm rad grill last night.. each of the grill are 360 degree adjustable...just for fun :D:
  15. Sometimes it's just easier to remove parts like the switches and led lenses instead of taping them off before we prep for custom paint. The Obsidian power and reset switches can be removed with a soldering iron.
  16. Of course you could always replace them with some fancy switches. I used your switch plate from your online store and a couple of those Bulgin style switches for a case mod.
  17. Next time tell me advance, I'll toss in a shirt. Thank you Johnny :D
    I thought about that too, but actually like Corsair's switch and I/O bay.
    The power switch bay all taped up, ready for prep and paint. Now I just need to decide what paint color I will do.
    Taping off the inside wall of the side panels from over spray.
  18. looking good
  19. Thank you climb!
    Anything you can remove instead of masking off, makes a custom paint job much more professional looking. If you decide to paint your Obsidian, you may or may not consider removing the panel release button and rod assembly.
    To remove the button, you'll need to poke in 4, release tabs with a small screw driver from the inside of the case.
    Red arrow shows location of one of the 4, plastic tabs
    Remove the release button trim ring in the same manner
    Then you can remove the 4, tiny black screws. The rod is attached to the front of the chassis in the same manner, but without the button assembly.
    Each rod has one spring one the button side.
    Store these springs and fasteners in a plastic bag so they don't get lost!
  20. The color sample book of the Paint Gods, HOUSE OF KOLOR
    Staying faithful to the Maple Leaf tied into design, I decided on Candy Apple Red.
    This mini "skull" was painted with the Candy Apple Red..... Imagine the Obsidian painted this color!
  21. This is really inspirational, being a welder/fabricator that is. Iv been wanting an Obsidian for ages and thought there was no chance but mine came (fri-5th-feb). Ill be going water cooling at some stage so im going in, lol. Great work and cant wait to see final product all the best monster.
    Dan
  22. Candy apple red? oooooohhhhhh - memories of hot rods, drag racing, and Big Daddy Don Garlits!
  23. Go Canada (it'd be cool if they showcased your case at the Winter Olympics)
  24. Thanks for tuning and commenting guys! I hope this project will the raise the bar for all customized Obsidian cases
    Here is some photos taken while we sandblasted the chassis. The factory finish on the 800D is very thick and coarse, so it required 80 grit blasting sand
  25. Here is the Obsidian chassis drying after final application of HoK Kandy Apple Red automotive paint.
  26. ooo sexy. Hey mawd got any tips for modding that owuld be a good plpace to start for a beginner? ( Mostly so far i want to mod the window in some way on my k-62, but not sure if i should with it having those weird things holding on the Pglass ).
  27. Wow this is looking great, its fitting since I feel that HardwareCanuks' case reviews are simply second to none.
  28. If you're going to do the entire exterior in candy apple red, then you need to add yellow flames just like a 1950's hot rod! :D
  29. @ truhls, Hi, I have several video guides on my YouTube page
    Guide to installing a window case mod
    @ AMW1011, agreed! I actually discovered them when they reviewed this exact case...lol
    @ JohnnyLucky, thats is sooo tempting...lol
  30. Been awhile since I have been on here MonsterMawd,
    But what can I say your mods always interest me. Loved your Antec 300 case mod, so much in fact that I have gone out and bought one at Micro center for only $44 bucks on sale and plan on modding it out...
    I just picked up a Q9950 and replaced bad caps on a Intel board that was given to me, (my first cap's repair and solder job) and It came out very nice, mother board is stable after 2 weeks of testing it. I plan on modding the Antec case and lining it with Granite inside and out, in a Granite color that will be in theme with Leopard colors and have a nice back lit Apple cut out of a white glass product. After looking through the X86 projects it will make a nice build for Retail Snow. I upgraded the graphics cards in my main rig I built the case by hand and lined with granite and dropped my 4870 into the Antec 300 rig.
    I was hoping you would mod this new case from Corsair, I can't wait to see what you guys come up with when it is finished. I have a guy that I have sold Three Apple laptops to that I have refurbed and upgraded to the max for, and there is a chance that he and some buddys are going to be getting a Laser Jet cutter and I will have access to it very soon and it will be at his home shop about 30 min from me. Looking at some of your mods that you have done, and knowing what can be done when your not doing ever thing by hand has me looking forward to some serious custom case mods, and builds of my own design.
    You inspire me, and I can't wait to see the case when it is finished! Nice choice on the Red btw, its the same I picked for my custom granite case I did a few months back.
    Keep the pics coming, can't wait to see the final product!
  31. yes, thats the look ! again great stuff. Cant stop messing with my case just need a paint job lol.
  32. Happy to hear that my project inspired you medjohnson! The 300 is great case for cost. Thank you for tuning into this project log and commenting :)
    Thank you for the post GRdiablo!
    Fresh coat of clear on the Red Candy Apple on the chassis.
    Yes, and the backside of the bezel was painted too!
  33. damn....nice job...aka AWESOME
  34. Lookin sweet, I'm sittin here all googly eyed n my old pc case is leanin away from me for some reason. lol
  35. Looking good. Post a pic of the finished case.
  36. Thanks for the nice feedback guys!
    Will do Johnny, still have side panels and grill to paint this weekend :)
  37. It's just so...........so..........purty
  38. It might be that red is my favourite colour that's making me drool more than usual over this mod! Looking forward to seeing how the grills are gunna look and if the colour is goin to be different. :pt1cable:
  39. Thanks guys! We should have the paint completed by this Friday!
  40. can't wait to see the pics MonsterMawd.... looking very good so far!
  41. Please post the finished pics of the case and nice job....
  42. everything is finished, just taking my sweet time with assembly, so nothing gets wrecked :pt1cable:
    5.25 bay covers are finished!
    Hot Swappable bay door :cool:
  43. The bezel is finished. I'm waiting for the sun to come back, so I can go outside and take photos of the paint.
    The Hot Swappable bay
  44. So far, everything looks good. Can't wait to see the finished polished job.
  45. Wow! Good stuff. I'm also all for the yellow flames on the side. :D
  46. very nice Monster, can't wait to see more
  47. Thanks everybody! I installed 140mm Xigmatek XLF-F1455 140mm cooling fan (1000 RPM, 63.5 CFM @ 16 dBA) cooling fan and billet "Hardware Canucks" grill mounted on the Hot Swappable bay.
  48. The rear Xigmatek XLF-F1455 140mm cooling fan (1000 RPM, 63.5 CFM @ 16 dBA) cooling fan and billet "Hardware Canucks" grill.
  49. Ok, back to more seXay images...
    To mount my Rad Grill / Case / Fan / Radiator sandwich, I use our M3 x 35mm length socket head stainless steel screws. These fit perfectly without the worry of piercing your radiator fins.
Power Supplies Hardware Cases Corsair Components
