I have Laing DDC1-t pump for the new build with two fullcover gpu blocks.
I will use the Y-fitting instead of reservoir in a modified Fractal R2 case(removed harddrive + DVD).
Build 2:
Fractal R2 case removed all front cages.
Front will have the Aquacomputer radiator(already measured it fits with som tweaking).
Laing DDC-1t with XPtop decoupled by shoggy sandwich.
2x Fullcover gpu blocks.
Cpu is cooled by Ninja plus rev.B air cooler.
The Y-fitting will go to rad and cpu and the other "arm" will go to a sealed tube which acts as filling tube/reservoir.
I will not have a reservoir in this build.
Build 1:
This build is currently working with 2radiators, D5 vario pump, and fullcover gpu block.
I'm considering removing the reservoir and replace it with a Y-fitting which will go to cpu, front rad and fillport in top.
I will also add a Fillport in the top hole and it is to my understanding 100% compatible with the one I ordered now.
I will decouple the D5 vario pump with Shoggy sandwich to even further minimize noises.
