Solved
EVGA GTX480 + Arctic Cooling Accelero Twin Turbo II Cooler = OC
  • Graphics Cards
  • EVGA
  • Cooling
  • Arctic
  • Overclocking
April 1, 2012 8:05:32 PM
Hi,
I have a EVGA GTX480 (the latest, 015-P3-1480-KR) and I've bought the "Arctic Cooling Accelero Twin Turbo II" cooler to it.
I did it first just because of the noise. The rest of my rig is virtually silent and the GPU itself was the noisiest component.
But I need to admit that I am IMPRESSED by this cooler.
Previously, my IDLE temp was about 45-50C (this WITH High-Flow Bracket) and with just some minutes of FurMark (like less then 10min) I used to reach 85-95C easily with no OC and with the stock cooler SCREAMING like a JET (95%+)!
Now, my IDLE with this cooler on minimum speed (30%) is like 35-40C and completely silent and under FurMark it NEVER passes 75C with the fan at 80% speed MAX, with very low noise.
So, now I am (of course) playing with OC on it :D
So, I've reach this config here completely stable (FurMark stable under 80C or less):
1.1V, Core 900MHz, Shader 1800MHz, Memory 2100MHz.
My questions are:
1) This config is safe?
2) Can I go higher?
Thanks! :D
More about : evga gtx480 arctic cooling accelero twin turbo cooler
a c 109 U Graphics card
a c 150 K Overclocking
April 1, 2012 10:37:35 PM
I don't see why not, the gtx 480 can handle temps of around 100C.
m
l
April 1, 2012 10:39:11 PM
I am more "concerned" with the memory because I don't know if that "temp" just shows CPU temp.
Since the new cooler just have "heatsinks" on the memories, I am concerned to overclock the memories too much...
m
l
April 1, 2012 10:41:27 PM
Tip about gpu overclocking, don't worry about memory just nuke the core/shaders.
m
l
April 1, 2012 10:45:47 PM
Really? But do you think that I can keep the memory stock clock and OC the core/shaders like hell? This will not create "weird behavior" / "artifacts"?
m
l
Best solution
April 1, 2012 10:50:30 PM
Usually, overclocking memory creates all of those weird artifacts, so I would only oc shader/core.
April 1, 2012 10:55:13 PM
Cool! Nice to know. I will try it.
Just for the record, I've created an "underclock profile" just to keep my board cool / silent when I am NOT gaming and it is AWESOME. Totally silent and the power consumption drops A LOT! Here it is: 825mv / 405MHz Core / 810MHz Shader / 920MHz Memory / 30% Cooler.
m
l
April 1, 2012 10:55:23 PM
Best answer selected by bsas.
m
l
April 1, 2012 10:58:49 PM
The card will underclock itself when you don't do anything, all I would do now is just create a custom fan profile.
m
l
April 1, 2012 11:23:55 PM
Really? But it will also undervolt? My concern was basically reduce power consumption so I can keep my rig "on" doing "simple folding".
m
l
April 2, 2012 12:11:01 AM
Yes, it will do all of that :)
m
l
