Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help with build, and power supply question
Forum Homebuilt Systems : New System Build - Help with build, and power supply question
APPROXIMATE PURCHASE DATE: 2-4 weeks
BUDGET RANGE: 900(1000 with tax)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming 80%, 10% internet, 10% college homeworks
PARTS NOT REQUIRED: Haf 932 case, 22" Samsung TouchOfColor monitor,OS
PREFERRED WEBSITE(S) FOR PARTS: Im buying from local store, and im not from the usa
PARTS PREFERENCES:
OVERCLOCKING: Yes, only the oc genie
SLI OR CROSSFIRE: No, since i dont have a big monitor
MONITOR RESOLUTION: 22" Samsung TouchOfColor 1680x1050
ADDITIONAL COMMENTS: Dont know which ddr3 refering to timings. Power supply will be futureproof? if by anycase i buy another vga in the future.
core i5 199
http://www.compusa.com/application [...] CatId=4729
corsair HX750W modular 154
http://www.compusa.com/application [...] VIEWS#tabs
Motherboard msi p55-cd53 129
http://www.compusa.com/application [...] CatId=4720
Ocz 4gb platinum 92
http://www.compusa.com/application [...] CatId=3361
Razer lycoza normal 59
http://www.compusa.com/application [...] CatId=3463
Seagate Barracuda 7200.12(f3 if available) 54
Mice death adder 59
Sata dvd 29
http://www.compusa.com/application [...] 1028%20OEM
5850 299
As you can see, this goes a little above even before tax. Any advice, maybe i should reduce power supply to 650? Any input will be appreciated, thx
Sponsored Links
^ Since you wont be going SLI/ Crossfire, I dont see the need for 750HX...Why not get the 750TX ? It would easily come inside your budget and if by any chance you would like to go Crossfire, it can easily handle that...
But even the Corsair 650HX(Not 650TX) has the required power connectors for Crossfire...
Rest are good...
Reply to gkay09
Rest are good...
though the corsair 650TX has the power for crossfire/sli setups, its a shame they didn't give it enough pci-e power connectors
Reply to mindless728
The motherboard doesnt support crossfire. He can drop all the way down to a 550W PSU with only 2 PCIE connectors.
You could save $40 and get a cheap logitech optical mouse. Put the non-essential gaming mouse on your xmas list so someone else can get it for you. Same with the keyboard.
Reply to dndhatcher
btw, can anyone help me using this psu calculator?
http://www.antec.outervision.com/PSUEngine
im overclocking with oc genie, and it does it to 3.5 ghz
Reply to tosen
@mindless728 Yes that is the reason why I had specifically said HX 650...
@tosen get the Corsair HX 650...it has enough power connectors for Crossfire/ SLI...
And for 3.5GHz overclock, the mobo might automatically increase the core voltage to 1.4/ 1.45 max...So check mark the overclock my CPU and give speed 3500, voltage 1.4 and click on overclock...
And 650W would suffice for HD 5850 crossfire along with o/c CPU...
Reply to gkay09
thx, i actually see the mobo and it doesnt support sli, this is cd53, the gd65 supports sli/crossfire but its for 40 more bucks.
I think that with 1 card i will be doing more than fine, so which psu would be good?
If its again the 650 hx then im getting the 750 hx, since theres only a 15 bucks difference.
Reply to tosen
^ For a single card, the Corsair 550VX would suffice...Actually any 80+ certified 500W PSU from any of these manufacturers - Corsair/ Seasonice/ Silverstone/ Antec EA/ Antec Truepower/ CM RealPower/ PCP&S...Even that OCZ Fatality 550W you linked would be good...
Reply to gkay09
forgot to say i currently have:
Core2duo E8400
4gb ram ddr2 400mhz
260 gtx oc BFG
Classic motherboard(doesnt allow to overclock)
320gb HD
Samsung drive
Audigy sound card
and the setup posted above will end like this:
Core i5(overclocked to 3.5 ghz)
4gb ram ddr3 dual channel 1033 mhz
5770 ati video card
Msi motherboard with oc genie
Samsung drive
500gb HD
Im selling my current pc for $600, and the new pc with tax would be around $950...worth it those extra $350 to get new pc?
link to said thread:
http://www.tomshardware.com/forum/ [...] bottleneck
Reply to tosen
^ That is a good upgrade and is worth $350...But in case you dint know, the HD 5770 would be slower than the GTX 260...The man advantages of the 5770 are that its next gen and features like the Eyefinity...But in raw power, the GTX 260 wins...
Reply to gkay09
There are 915 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
