Need help..
Forum Homebuilt Systems : New System Build - Need help..
I just built my new system and booted up for the first time and it goes to the logo for the motherboard and then goes black and says:
Reboot and Select proper Boot device or insert boot media in selected boot device and press a key.
I don't have any idea of what to do?
My system specs are:
MSI 790FX
phenom 2 x4 665
dual 4890's
intel x25-m 80gb
Sponsored Links
This means that either you don't have an OS installed, your SSD is bad (or disconnected), or you mobo's sata ports are bad (least likely).
Reply to pepperman
Agreed, make sure the operating system is properly installed and all cables are securely plugged in. Also, make sure you plugged in the power cord to the hard drive.
If all of that is correct, go into bios, and make sure your hard drive drive (probably C: ) is set as the primary boot device, and that the cd drive isnt.
Message edited by hypocrisyforever on 11-13-2009 at 08:16:31 PM
------------------------------ "Since the dawn of time, man has dreamed of blotting out the Sun." - J. Montgomery Burns
Reply to hypocrisyforever
I don't see anything wrong. He's suppose to see that message if he booted up for the first time without any OS installed.
Reply to masterasia
Lol, I'm (perhaps foolishly) presuming that if he built a system from the ground up, he understands the need for an OS :-P
My first thought as well.
------------------------------ i7 860 | GA-P55M-UD2 | 4GB G.Skill 1600 CAS9 | Radeon HD 4670 | Corsair CMPSU-450VX | WD Caviar Black 640GB | Sony Optiarc Black 24x | CM Elite 310 | Dell UltraSharp 2208WFP (1680x1050) | Windows 7 Pro x64
Reply to ekoostik
I completely forgot I posted this, seems like forever ago. Everything was fine I just needed to press delete to get into the Bios. I hadn't yet installed the OS. Anyways I have my pc up and running nicely, thanks.
Reply to RAB86
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need help..
There are 635 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
