can i put some memory on my mobo with not disame product but same size? tnx for the one who reply..
K kimmj2806 Distinguished Apr 16, 2010 26 0 18,530 May 17, 2010 #1 can i put some memory on my mobo with not disame product but same size? tnx for the one who reply..
L Lmeow Splendid Mar 14, 2010 3,096 0 21,460 May 17, 2010 #2 Possibly, although different memory speeds, timings and voltages may cause compatibility issues.
outlw6669 Splendid Dec 4, 2006 4,821 1 23,460 May 17, 2010 #3 If you match the speed, timings and voltage of your current set, it shuold work just fine.
FunSurfer Distinguished Oct 26, 2009 960 36 19,240 May 17, 2010 #4 You should not have any issues if you will match the new RAM name to the old one. For instance, the name of the DDR3-1600 is PC3 12800.
