Hi, this is my first post here so I hope it's in the correct forum. Apologies in advance if it should be somewhere else.
I'm having a minor problem with the USB wireless adapter on this computer. Nothing major - just an annoyance really. Basically, when I switch the computer on it doesn't activate (no power LED), even though it's plugged into a USB port (on the PC, not a hub).
If I then pull the USB cable out and plug it back in it switches on immediately and is up and running in a few seconds. Afterwards it works fine even if I soft-reboot the computer. It doesn't need to be unplugged-and-plugged again til next time I start the machine from cold.
I also have a USB scanner and a USB printer attached and they both start just fine.
Anyway, here's the tech specs:
Adapter is an Edimax EW-7711UAn USB
Computer is running Windows XP Home SP3
If you need any further details or have any ideas then please let me know. All help greatly appreciated.
Thanks,
Yoss
Thanks,
Yoss
