Tom's Hardware > Forum > Home Theatre > ReplayTV > Sharing problem
Sharing problem
Forum Home Theatre : ReplayTV - Sharing problem
Archived from groups: alt.video.ptv.replaytv (More info?)
Setup = 5080 wired ethernet connected thru SMC router
Had sharing set up and working for long time. Suddenly stopped working with
no changes made. I accept show and download stays at 0% and when I check
later always says "network errors, check your internet connection." I can
send shows OK.
The device connects to server no problem ever. Online support worthless (1
email asking boilerplate questions every 2 weeks).
Any ideas?
Thanks in advance
Sponsored Links
Does it happen with ALL downloads or just some? I had a similar problem
about a year ago and found that some downloads caused problems while
others were fine even though it was the same show from multiple sources.
Is the source d/l'ing to others at the same time? that can cause a
problem too. I'll be happy to send you something if you need another d/l
to test.
tnc3p@yahoo.com
> working with no changes made. I accept show and download stays at 0%
> and when I check later always says "network errors, check your
> internet connection." I can send shows OK.
> worthless (1 email asking boilerplate questions every 2 weeks).
> Any ideas?
> Thanks in advance
Reply to Anonymous
>send shows OK.
Is that Replay's LAN IP (not your public WAN IP) dynamic or static? If
dynamic, has it changed? That will break port forwarding. This will
not affect central server connects, but will affect show sharing.
I had a dynamic IP at first. The a software upgrade made it change 2-3
times a week, so I changed to static. It's easy to do.
>Any ideas?
>Thanks in advance
Mark Lloyd
http://go.to/notstupid
http://notstupid.laughingsquid.com
"It is a curious thing that every creed promises a
paradise which will be absolutely uninhabitable for
anyone of civilized taste." -- Evelyn Waugh
Reply to Anonymous
Happens w ALL downloading...appears to start but never progresses past 0%.
SMC uses virtual server function (= port forwarding) where port linked to
fixed IP (my LAN) address of RTV.
?I could try to put the RTV in DMZ but lose firewall. dont know how much
problem with hacking there is.
"BruceR" <brNOSPAM@hawaii.com> wrote in message
news:1iZdc.2459$162.516@twister.socal.rr.com...
> to test.
> From:Terence
> tnc3p@yahoo.com
> > Any ideas?
> > Thanks in advance
Reply to Anonymous
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
