I'm very much a noob when it comes to overclocking. I'm trying to do a slight overclock on my i5 750 with Asus Maximus III Formula mobo. I want it at 3.6 ghz, which I have achieved, but the DRAM Timings has changed. The RAM is supposed to run at 9-9-9-24 according to spec. The way I have it overclocked, it runs at 9-10-10-27 at 1440MHz (specced at 1600MHz). Is this a problem? The settings I'm using are as follows.
BCLK = 180
CPU Mult = 20
Turbo disabled
C1E Enabled
EIST Enabled
QPI Auto
Load Line Calibration Disabled
CPU voltage 1.225
DRAM Voltage 1.545
PLL 1.81
I have it working and it seems to be stable at the moment, but I was just curious about this. If anyone has any suggestions, I'm definitely open to any. Thanks in advance
Edit: Prime 95 gave me errors almost immediately after starting it up again. I googled the error and it appears to be an issue with Memory. I reset bios to defaults and ran again without that error. I'm definitely confused now, because this configuration worked earlier...
BCLK = 180
CPU Mult = 20
Turbo disabled
C1E Enabled
EIST Enabled
QPI Auto
CPU voltage 1.225
DRAM Voltage 1.545
PLL 1.81
