Hello, I'm purshasing my new rig by the end of next week. It's an i5 2500k build which I want to overclock @4.2-4.5GHz
Where I live, max temps are around 35-42ºC in summer, so I'm a bit worried about my new rig's cooling if I achieve that overclock.
My case choice is the Antec 300, which comes with 2 fans (120mm rear, 140mm top) with adjustable speed (Low, Medium, High). As far as I know, these are those fans specs:
Antec 300 140mm fan
rpm 700 / 19.8 dBA / 47 CFM
rpm 1100 / 21.4 dBA / 66.8 CFM
rpm 1500 / 31.8 dBA / 94.1 CFM
Antec 300 120mm fans
RPM 1200 / 25db / 36cfm
RPM 1600 / 28db / 56cfm
RPM 2000 / 30db / 79cfm
CPU cooler: CM Hyper 212 evo
So, now I'm trying to decide which fans to get for the 2 front fan slots that the Antec 300 has.
I'm between these 2 options (120mm):
Scythe S-FLEX - rpm 1200 / 20.1 dba / 49 CFM
Scythe S-FLEX - rpm 1600 / 28 dba / 63.7 CFM
1) I've read some good reviews about the 800-1200rpm ones, but would they be enough considering summer temps here?
2) Is 28dba too noisy?
Thanks!
Antec 300 140mm fan
Thanks!
