Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Problems getting New Motherboard set up (audio/network)
Forum Homebuilt Systems : General Homebuilt - Problems getting New Motherboard set up (audio/network)
Hey all, I just finished my i7 920 build, and everything is working perfectly -- except for two things: my audio and my internet connection.
So I just built this build, an i7 920 with an EVGA SLI LE motherboard. Everything is working perfectly, the system is extremely responsive, I love the speed. The 920 stays very cool. I am running Windows 7 64bit.
Audio Problem: Since the 1st day I installed the motherboard, the rear audio ports have been for all intents and purposes, dead. I can't figure out what I'm doing wrong. The realtek software is installed, and it can even detect when I plug the speakers into the jack, but the sound never comes out! The front panel audio connection does work, however (no idea why). What can I do to troubleshoot this? its very frusturating to be without sound.
Internet Problem: When I first installed the system, I just plugged the network cord into the motherboard, and everything worked perfectly. For the last three days, however, I've had an odd problem. Here is the message Windows keeps giving me: "Windows has detected an ip address conflict Another computer on this network has the same ip address as this computer. Contact your network administrator for help resolving this issue. More details are available in the Windows System event log."
What can I do to solve this? No, I have never connected this computer to the network via wireless (2 operating systems ago I did, but not since loading Windows 7). What can I do?
Thanks!
------------------------------ Core i7 920 <> EVGA SLI LE <> Corsair Dominator 1600 3x2 (6gb)
Velociraptor <> Corsair 750W <> Visiontek Radeon 3870
Sponsored Links
Any ideas at all where to start troubleshooting this?
I rlly need my internet back
Typing this on my blackberry
Reply to ajsellaroli
guys I need to use my computer!!! ideas!? I know i have a static Ip, and that when u check any computer in my house with whatismyip.com it always gives us the same one, but it has never caused a problem until now
whats happening help!?
Every other computer in this house (4 others) are still having no problem connecting to the network!! They are all on XP, I am the only one on Windows 7!
From each computer, click
start
run
Type cmd
type cd\
type ipconfig
check the last number of ip address of all 4 computers. If there's 2, then one might have a static IP address (the 920) assigned and the other has a dynamic. They dynamic could have been assigned while the static wasn't connected and when the static tries to connect, its IP addy is occupied.
There's two sides to a router divided by the firewall. Website based IP detectors will only make it as far as the firewall and find the routers IP WAN (wide area network, aka the internet) address. The router gives each device its own IP address on the LAN (local area network) when they log on if the lan address is static, use that.
Message edited by skora on 11-16-2009 at 02:08:09 AM
------------------------------ TheAnimal's - HOW TO ASK FOR BUILD ADVISE - Use this FORMAT
sKora's Design Guide
Reply to skora
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
