New build, having some problems that I just cant figure out.
Specs
i7 860
Gigabyte p55a-ud3
8gb adata Gamer 1600 (on compatibility list) running at 1333
Antec 650 earthwatts
First, nothing is overclocked, I just want stability at stock speeds. It appears stable overall, at least at first, I had one blue screen installing 7, but after a restart it installed fine. Pcmark ran without a hitch, and everything seemed ok till I started installing all my larger apps. It took me a few tries to install Adobe CS4, I had a few errors and a blue screen (irql_not_less_or_equal).
I ran prime95 and all seems well if I run the small fft or large fft tests. But if I ran the blend test, one worker would error out the moment I started the test. It was never the same worker and it was completely random, this happened like 8 times in a row. I let it rest for a few minutes and tried the blend test again and it was fine. I cant get the errors to repeat.
I have run memtest 4.00+ twice overnight and both times I had over 6 passes and 0 errors, so I dont think the ram is to blame.
These issues seem quite random to me and really have me confused, any ideas? Thanks
Specs
i7 860
Gigabyte p55a-ud3
