Im new to PCs and was wondering this question.. I have an i5 2400. I had the stock cooler on it and it was pretty quiet. I then had a credit from newegg and bought the CM 212 evo cooler. It seems to be running the temps better than the stock cooler, as expected. The idle is around 28-29c the lowest core is 23c. But here is the catch, the fan is running on 100% ( via speed fan ) I know I can adjust it via Speedfan, but is there anything that will adjust it automatically when the heat rises?
If so what threshold should I have the fan ramp up at, as in what temp should the fan increase say 50% speed to 75% speed then 100% speed? ( if possible ) thanks!
BTW I have an ASRock h61m/u3s3
