Does the Double D card follow the reference layout? I have searched and searched, but can't find any official info on the layout of the double D card. I'm 90% certain that the only difference between the double D and the single fan card is the heatsink, but I can't be certain.
My card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150515
The GPU water block I'm wanting to buy:
http://www.koolance.com/water-cooling/product_info.php?product_id=2004
Is there a way I can tell if the water block will fit my card?
My card:
