Ethanol is alcohol, just that it is made from grain (suitable for drinkin) vs Isopropanol and Methanol which is derived from wood (NOT suitable for drinking). Methanol and Isopropanol are commonly used to wipe down equipmant that is taken into a cleanroom enviorment.
100% (200 proof) Ethanol is hard to come by and usally has a tax sticker on it.
"rubbing Alcohol" up to 91% (9% is water) is common and cheap ar a drugstore. I have a source for 100% Isopropanol which is what I use.
Any of the 3 evaporates quicky with no residue
Quote
Ethanol, also called ethyl alcohol, pure alcohol, grain alcohol, or drinking alcohol, is a volatile, flammable, colorless liquid. It is a psychoactive drug and one of the oldest recreational drugs. Best known as the type of alcohol found in alcoholic beverages, it is also used in thermometers, as a solvent, and as a fuel. In common usage, it is often referred to simply as alcohol or spirits.
Isopropyl alcohol (also isopropanol, propan-2-ol, 2-propanol, rubbing alcohol or the abbreviation IPA) is a common name for a chemical compound with the molecular formula C3H8O. It is a colorless, flammable chemical compound with a strong odor. It is the simplest example of a secondary alcohol, where the alcohol carbon is attached to two other carbons sometimes shown as (CH3)2CHOH. It is a structural isomer of propanol.
Methanol, also known as methyl alcohol, wood alcohol, wood naphtha or wood spirits, is a chemical with the formula CH3OH (often abbreviated MeOH). It is the simplest alcohol, and is a light, volatile, colorless, flammable liquid with a distinctive odor very similar to, but slightly sweeter than, ethanol
